HOW TO
This document contains a VBA example that zooms to the XY domain of the selected layer in ArcMap's Table of Contents.
Code in ThisDocument code module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
Code:
Public Sub ZoomToDomainExtent()
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pActiveView As IActiveView
Dim pContentsView As IContentsView
Set pMxDoc = Application.Document
Set pMap = pMxDoc.FocusMap
Set pActiveView = pMap
Set pContentsView = pMxDoc.CurrentContentsView
Dim pLayer As ILayer
Dim pDataSet As IDataset
Dim pFeatureLayer As IFeatureLayer
Dim pGeoDataset As IGeoDataset
If Not TypeOf pContentsView.SelectedItem Is ILayer Then Exit Sub
Set pLayer = pContentsView.SelectedItem
Set pFeatureLayer = pLayer
Set pGeoDataset = pFeatureLayer
Dim pSpatialReference As ISpatialReference
Dim pEnvelope As IEnvelope
Set pSpatialReference = pGeoDataset.SpatialReference
Set pEnvelope = New Envelope
Dim dXmax As Double
Dim dYmax As Double
Dim dXmin As Double
Dim dYmin As Double
pSpatialReference.GetDomain dXmin, dXmax, dYmin, dYmax
pEnvelope.XMax = dXmax
pEnvelope.YMax = dYmax
pEnvelope.XMin = dXmin
pEnvelope.YMin = dYmin
pActiveView.Extent = pEnvelope
pActiveView.Refresh
End Sub
Article ID:000005068
Get help from ArcGIS experts
Download the Esri Support App
