HOW TO
Verify the installation of Deep Learning frameworks in ArcGIS Pro
Last Published: August 16, 2024
Summary
The deep learning geoprocessing tools in ArcGIS Pro are a set of powerful tools that leverage machine learning algorithms to analyze spatial data. These tools require the installation of supported deep learning framework libraries. Refer to ArcGIS Pro: Install deep learning frameworks for ArcGIS for additional information.
This article provides a guide on how to confirm the successful installation of these libraries.
Procedure
Ensure the version of the deep learning libraries installed is compatible with the version of ArcGIS Pro installed on the machine. For example, Deep Learning Libraries for ArcGIS Pro 3.2 is not compatible with ArcGIS Pro 3.3.
Verify the installation of the deep learning libraries via the Package Manager in ArcGIS Pro
Check the Package Manager in ArcGIS Pro to verify the installation of the deep learning libraries. Refer to Learn ArcGIS: Verify the installation is successful for instructions.
If the package is not listed in the Package Manager, refer to the solution below. In some instances, the package may not be listed in the Package Manager in ArcGIS Pro despite being installed on the machine.
Verify the installation of the deep learning libraries via the Python Command Prompt
  1. In the Windows search box, type python command prompt, right-click Python Command Prompt, and click Run as administrator.
  2. In the Python Command Prompt window, copy and paste the following command and press Enter.
conda list
  1. Verify that the deep-learning-essentials package is listed.
Article ID: 000031742
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
