HOW TO
Use Windows True Type Fonts in ARCEDITW
Summary
This article describes how to display Windows True Type Fonts in a DAK ARCEDITW session.
Procedure
  1. Click Options in the DAK graphics windows (usually labeled DAK.G0).
  2. Click Fonts.
  3. Choose the desired Font and Font Style/Effect parameters from the pull down menus. Make a note of what the Font Number is. The Font Number will be displayed and should start with the negative sign.
  4. Click the OK button.
  5. Choose File > Command. This will put you in command mode so you can type commands manually.
  6. Type
    Code:
    EDITCOVERAGE [COVERAGE_NAME]
  7. Type
    Code:
    DRAWE ARC LABEL IDS
  8. Type
    Code:
    DRAW
    This will draw the Label ID's in the standard font.
  9. Type
    Code:
    TEXTSET *
    : SYMBOL: 1
    : COLOR: 1
    : STYLE: 1
    : FONT: <value from step 3>
    : QUALITY: 1
    : ANGLE: 0
    : WIDTH: 0
    : HEIGHT: 0
    : CHARACTER GAP: 0
    : LINE GAP: 0
  10. Type
    Code:
    DRAW
    Now you will see the Label ID's drawn in the desired Windows True Type Font
    For the display of ID's, only the TEXTSET | SYMBOL number 1 is utilized.
Article ID:000005554
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
