HOW TO
Use the Split tool to export each feature in a feature class to individual feature classes
Last Published: June 3, 2022
Summary
Instructions provided describe how to use the Split tool to export each feature in a feature class to individual feature classes.
The Split tool can be used to export each feature in a feature class to individual feature classes. For example, if a feature class has 50 features, it exports each feature to its own feature class, resulting in 50 new feature classes.
Procedure
  1. In ArcMap, start the Split tool by navigating to Geoprocessing > ArcToolBox > Analysis Tools > Extract > Split.
  2. For Input Features, navigate and select a polygon feature class.
  3. For Split Features, select the same feature class as selected for Input Features.
  4. For Split Field, select a text field that uniquely identifies each record. This field is used to name the output feature classes.
  5. For target workspace, select a folder or geodatabase where the output feature classes is to be saved.
  6. Click OK.
Article ID: 000008282
Software:
  • ArcMap 9 x
  • ArcMap 10 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
