HOW TO
Instructions provided describe how to use tangent bearings in COGO. The tangent bearing can be used by finding the radial bearing, the bearing pointing to the curve's center, if the tangent bearing is going into the beginning point. Once the radial bearing is known, the TRAVERSE command can be used.
radius
tangent bearing
arclength
The TRAVERSE command only accepts the following curve parameters:
arclength
chord
delta
radius
radial direction (non-tangent curve)
tangent
Code:
Arcedit: &ty [calc [angrad s63-27-56e] + [angrad 90]]
7.390868213232
Arcedit: &ty [radang 7.390868213232 -dms -bearing]
N26-32-04E
Code:
Arcedit: TRAVERSE OPEN 0,0
course (1): N79-03-04W 10.83
course (2): N11-20-30E 161.46
course (3): NTCLEFT RDDRN N26-32-04E
Article ID:000003566
Get help from ArcGIS experts
Download the Esri Support App
