HOW TO
You can use SQL functions, such as MIN, MAX, SUM, and DISTINCT, with IQueryDef to retrieve information about column values. You cannot use SQL functions with IQueryFilter or ISpatialFilter.
You can improve performance of processing large files, up to 100 times depending on the RDBMS and server resources, by using native SQL function instead of an IDataStatistics object. The down side of using SQL native function is that this will only work against an RDBMS; it will fail with shapefiles and ArcInfo coverages.
You can use the IQueryDef::WhereClause method to supply selection logic. Versioned data is supported.
Code:
Dim pWorkspaceFactory As IWorkspaceFactory
Set pWorkspaceFactory = New SdeWorkspaceFactory
Dim pPropertySet As IPropertySet
Set pPropertySet = New PropertySet
With pPropertySet
.SetProperty "Server", "testserver"
.SetProperty "Instance", "5253"
.SetProperty "Database", ""
.SetProperty "user", "testuser"
.SetProperty "password", "testpassword"
.SetProperty "version", "sde.defaults"
End With
' Open the connection to SDE
Set pWorkspace = pWorkspaceFactory.Open(pPropertySet, Me.hWnd)
Dim pFeatureWorkspace As IFeatureWorkspace
Set pFeatureWorkspace = pWorkspace
Dim pQueryDef As IQueryDef
Set pQueryDef = pFeatureWorkspace.CreateQueryDef
Code:
pQueryDef.Tables = "parcels"
pQueryDef.SubFields = "min (parcels_id)"
pQueryDef.WhereClause = ""
Dim pCursor As ICursor
Set pCursor = pQueryDef.Evaluate
Dim pRow As IRow
Set pRow = pCursor.NextRow
Debug.Print pRow.Value(0)
Code:
pQueryDef.SubFields = "max (parcels_id)"
Dim pRow As IRow
Code:
pQueryDef.Tables = "counties2"
pQueryDef.SubFields = "distinct (state_name)"
Dim pRow As IRow
Dim iRecCount As Integer
iRecCount = 0
Do
iRecCount = iRecCount + 1
Loop Until (pRow Is Nothing)
Debug.Print iRecCount
Article ID:000004678
Get help from ArcGIS experts
Download the Esri Support App
