HOW TO
Stubs, client side code including .class files, sometimes fail to work with versions of Glue other than the version they were created with. To generate stubs specifically for the currently installed version of Glue, use the wsdl2java command.
Code:
c:/> wsdl.WSDL2Java http://www.arcwebservices.com/services/v2006_1/glue/PlaceFinderSample.wsdl -p aws.v2006_1.gluestubs -g
Run this command from the same directory as the Glue license file: either glue-license.xml or webMethods-license.xml.
Article ID:000007064
Get help from ArcGIS experts
Download the Esri Support App
