Summary
In ArcGIS Experience Builder, there is no direct way to use an image as the page body background. The only available customization for the body background is a solid or custom color. However, it is still possible to use an image as the background by using the Image widget or the window function. This article outlines the workflow to use an image as the page background.
Procedure
Create the background image using the Image widget
- In ArcGIS Experience Builder, click + Create new.
- On the Blank fullscreen card, click Create.
- On the top ribbon, click <Untitled experience> and specify a name for the experience.
- On the side toolbar, click the Insert button.
- On the Insert widget panel, under Page elements, drag and drop the Image widget onto the canvas.
- In the Image pane, click the Select an image button.
- In the Select an image pane, select or upload the intended image.
- Resize the image to the preferred size.
Create the background image using a fixed window
- On the side toolbar, click Page > Window.
- Click the Add window icon and click Blank window.
- Resize the blank window to the preferred size.
- In the Window pane, under Background, next to Image, click Browse.
- On the Page panel, click the Page tab.
- In the Page pane, under Open with Window, select the newly created window from the drop-down list.
The experience below shows the completed canvas of an image as the background.
