HOW TO
Instructions provided describe how to perform Frequency commands for numeric fields in ArcMap using VBA and ArcObjects. ArcInfo has a Frequency command that returns a list of unique code occurences and their frequency for numeric and text fields.
Code in the ThisDocument module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
Code:
Sub TestHistogram()
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pMap As IMap
Set pMap = pDoc.FocusMap
Dim pLayer As IFeatureLayer
Set pLayer = pMap.Layer(0)
Dim pTable As ITable
Set pTable = pLayer.FeatureClass
Dim pTableHistogram As ITableHistogram
Set pTableHistogram = New TableHistogram
Dim pHistogram As IHistogram
Set pHistogram = pTableHistogram
' Get values and frequencies for STATE_FIPS
' for the US Counties layer into a table histogram object
pTableHistogram.Field = "STATE_FIPS"
Set pTableHistogram.Table = pTable
Dim dataFrequency As Variant
Dim dataValues As Variant
pHistogram.GetHistogram dataValues, dataFrequency
' Loop through the values returned by GetHistogram
For i = LBound(dataValues) To UBound(dataValues)
Debug.Print dataValues(i) & " " & dataFrequency(i)
Next i
End Sub
Article ID:000004957
Get help from ArcGIS experts
Download the Esri Support App
