HOW TO
ArcGIS for Excel supports multi-user editing, with some functionalities limited to editing existing rows and inserting new ones. Editing existing rows and adding new rows is possible. Inserting columns and deleting rows are not supported.
Users have the ability to share worksheet links across different Microsoft tenants by adjusting the permissions on the shared Excel link.
Note: Adding layers requires a refresh, as symbology changes are specific to the map.
To view added columns, refresh the layers; a browser refresh alone will be ineffective.
When editing a cell, those changes are immediately visible to others on the spreadsheet. However, updates on other users' maps will experience up to a 10-second delay.
Editing in hosted tables is also supported.
Furthermore, when a new layer is added to the map, it does not appear in others' table of contents immediately. Reload either the browser or the task pane to view the newly added layer.
Best practices for multi-user capabilities in ArcGIS for Excel require that the Excel document be shared.
 and select the desired sharing level.
 icon to open the Link settings window. Toggle who the link will work for. Click Apply to return to the sharing window.
Note: If a workbook is not shared publicly, only members of the organization will be able to see the workbook and map.
Article ID: 000035102
Get help from ArcGIS experts
Start chatting now
