HOW TO
The View.Locate address finding function is fairly rigid in operation, it only accepts the highest score. The code in this article will allow you to pick an address match based on a list of possible matches.
Code:
'-- Script: ModLocat.ave
'-- This script allows you to modify the operation normally handled
'-- by the View.Locate script. It asks for an input address and
'-- searches for candidates. If no candidates are found, the
'-- user is told and the process is safely stopped. If there is
'-- one candidate found, the point is located and placed on the
'-- view. If there are more candidates found, the user is given a
'-- choice to pick one. The number of the chosen candidate is
'-- sent back to the MatchCase object, to pull out the correct
'-- candidate. A point is the located and placed on the view.
'-- Prepare the geocoding scenario
theView = av.GetActiveDoc
theGL=theView.GetGraphics
theTheme = theView.FindTheme("Streets")
input = msgbox.Multiinput("Enter an address: ", "Input",
{"House Number: ", "Street Name: "}, {"", ""})
if (input = nil) then
exit
end
hsenumber = input.get(0)
name = input.get(1)
addrinput = hsenumber++name
msgbox.info(addrinput, "Is this the address?")
aMatchSource = theTheme.GetMatchSource
aMatchSource.OpenIndex
aMatchKey = Matchkey.Make("us_addr.stn")
aMatchKey.AllowIntersections("us_intsc.stn", "&")
aMatchCase = MatchCase.Make(aMatchSource, aMatchKey)
aMatchCase.AllowIntersections(aMatchSource, aMatchKey)
'-- Match the user-input address to the GBF
aMatchKey.SetKey(addrinput)
numcand = aMatchSource.Search(aMatchKey, 80, aMatchCase)
'-- If there are no candidates
if (numCand = 0) then
msgbox.info("Cannot locate address"+NL+"No candidates","")
exit
end
'-- If there is only one candidate
if (numCand = 1) then
aMatchCase.ScoreCandidates
cand = aMatchCase.GetBestCand
thePt=aMatchSource.GetPoint(cand)
theGPt=GraphicShape.Make(thePt)
theGL.Add(theGPt)
theView.Invalidate
exit
end
'-- If there is more than 1 candidate
addrList = {}
if (numCand > 1) then
msgbox.info(numCand.asstring, "This is the number of candidates")
for each int in 1..numCand
cand = aMatchCase.getnthCand(int)
addrstr = cand.GetValue(aMatchSource.GetMatchFields.Get(4))
addrstr2 = cand.GetValue(aMatchSource.GetMatchFields.Get(5))
addrstr4 = cand.GetValue(aMatchSource.GetMatchFields.Get(6))
addrstr6 = cand.GetValue(aMatchSource.GetMatchFields.Get(7))
'addrinfo = addrstr.trim++addrstr2.trim++addrstr4.trim++addrstr6.trim++int.asstring
addrinfo = addrstr2.trim++int.asstring++cand.getscore.asstring
addrList.Add(addrinfo)
end
theChosenAddrRaw = msgbox.ListAsString(addrList, "Choose one of the following:",
"Select which address you want to be the match")
theCandNumber=theChosenAddrRaw.extract(theChosenAddrRaw.Aslist.Count - 2).asnumber
theFinalCand = aMatchCase.getnthCand(theCandNumber)
thePt=aMatchSource.GetPoint(theFinalCand)
theGL.Add(theGPt)
theView.Invalidate
end
Article ID:000004170
Get help from ArcGIS experts
Download the Esri Support App
