HOW TO
This article discusses ways to obtain the extents of features in a map layer using Python scripting.
If a feature layer has a coordinate system, the coordinate system is obtained from the layer's data source. If the coordinate system of the map data frame is different from that of the layer, the layer is reprojected dynamically to the coordinate system of the data frame. Calling the ArcPy method 'getExtent' on a map layer returns the layer extents expressed in the units of the data frame's coordinate system.
However, it might be necessary to obtain the layer extents in the unit of the layer's coordinate system. In that case, use the ArcPy Describe object to obtain the extent property relative to the layer's data source.
Below is an example script to be run from a toolbox, where the input parameter is a map named 'Test1.' The data frame in this map has a geographic coordinate system 'GCS_North_American_1983' with angular units of degrees. There is one layer with a projected coordinate system 'North_America_Equidistant_Conic' containing linear units of meters.
import arcpy, os, sys mapPath = arcpy.GetParameterAsText (0) # Test1.mxd mxd = arcpy.mapping.MapDocument (mapPath) layerList = arcpy.mapping.ListLayers (mxd) for layer in layerList: arcpy.AddMessage ("layer name: " + layer.name) arcpy.AddMessage ("layer extent in c/s of dataFrame: " + str(layer.getExtent())) desc = arcpy.Describe (layer) if layer.supports ("DATASOURCE"): descDS = arcpy.Describe (layer.dataSource) arcpy.AddMessage ("layer extent in c/s of dataSource: " + str(descDS.extent))
Sample results:
Running script Script1... layer name: U.S. States (Generalized) layer extent in c/s of dataFrame: -180.112396694215 8.88321931557688 180.112396694215 79.3719235333962 NaN NaN NaN NaN layer extent in c/s of dataSource: -6047698.3142 -1568756.4536 2122393.9964 4372931.5431 NaN NaN NaN NaN Completed script Script1...
Article ID: 000011838
Get help from ArcGIS experts
Download the Esri Support App
