HOW TO
Use ArcGIS Drone2Map 2025.1 and newer with ArcGIS Enterprise 11.3 and older
First Published: March 4, 2025
Last Published: August 5, 2025
Summary
This technical article is provided for organizations using ArcGIS Enterprise 11.3 and older who are seeking to license and use ArcGIS Drone2Map 2025.1 and newer.
Procedure
ArcGIS Drone2Map 2025.1 has been updated to provide further security and performance enhancements and now requires an upgraded license manager. You will need to upgrade to the latest version (2025.0) of the ArcGIS License Manager if you are on ArcGIS Enterprise 11.3 and older.
You can use the following workflow documentation to upgrade your license manager: License manager installation and startup
Once the license manager is upgraded to 2025.0 you should be able to license as you would previously through named user licenses assigned from the organization.
Article ID: 000035094
Software:
  • ArcGIS Drone2Map
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
