HOW TO
Use an external web browser to sign in to ArcGIS Survey123
Last Published: April 27, 2022
Summary
By default, the ArcGIS Survey123 field app and Survey123 Connect both have an embedded web view for signing in to the app. Both apps also support launching an external web browser for signing in.
Reasons for using an external web browser to sign in include:
  • Security policies that dictate specific web browser use
  • Requirements for using web browser credential management
  • Screen size and resolution behavior
Whether using the embedded web view or an external web browser, the same OAuth sign-in page is displayed.
The ability to use an external web browser to sign in is already configured for ArcGIS Online and Portal for ArcGIS.
Procedure
While older versions of Survey123 required configuration to launch an external web browser for logging in, the current versions have a simple button that can be enabled.
Whether adding a Portal for ArcGIS URL or ArcGIS Online URL, the option to "Use external web browser for sign in" can be enabled when adding the portal.
If using ArcGIS Online, it is already listed in your active portals by default. You must select "Add Portal" and re-add your full organization URL to the list to be able to select that option for sign-in, as seen above.
Article ID: 000015936
Software:
  • ArcGIS Survey123 Field App iOS
  • ArcGIS Survey123 Field App Android
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
