Summary
After authoring a basemap, it can be used in both ArcGIS Pro and ArcGIS Online. It can simply be added as a layer in the Contents pane, but this can also be done more formally by the following steps.
ArcMap cannot be used because tile and vector tile formats are not compatible.
Procedure
ArcGIS Pro
- From the Catalog pane, right-click the Maps folder and select New Basemap, as shown in the next image.
- This can also be done from the Insert tab > New Map drop-down menu.
- Add the layers to use for the basemap. In this example, the next image shows that a custom basemap style and a hillshade were used:
- Save all the changes.
- Alternatively, if there are existing standard maps with the layers required, they can be converted to avoid re-creating them: Right-click the map from the Catalog pane > Maps, point to Convert and select Basemap.
- From the Map tab > Layers group > Basemap drop-down menu, the one just created is listed, as shown in the next image.
ArcGIS Online: Map Viewer
- From the Contents toolbar, click Basemap > Current Basemap.
- Click the Add button.
- Search for the layer to use. In this example, a custom basemap style was used. These are compatible formats:
- Tile layer
- Tile imagery layer
- ArcGIS Server Web Server
- OGC Web Map Service (WMS)
- OGC Web Map Tile Service (WMTS)
- Click the back arrow and the layers are now listed as the basemap.
- The name can also be changed.
ArcGIS Online: Map Viewer Classic
- Click the Add tab and insert the layer to use.
- Once added, click Options and select Move to Basemap.
- Note that it is included in the Topographic group layer.
