HOW TO
Update the ArcGIS Pro license server in the registry through a batch script
First Published: December 19, 2023
Last Published: December 19, 2023
Summary
To update the ArcGIS Pro license server information on multiple machines, customers can use a batch script. This is useful when an organization has switched to a new license server with a different hostname or IP address.
Procedure
Caution:
Please note that this script modifies the Windows registry. It is recommended to back up your operating system and files, including the registry, before proceeding. Also, ensure that you have administrative privileges to make changes to the registry.
  1. Open a text editor such as Notepad.
  2. Copy and paste the following code into the text editor:
@echo off
setlocal
set KEY_NAME="HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Licensing"
set VALUE_NAME="LICENSE_SERVER"
REG ADD %KEY_NAME% /v %VALUE_NAME% /t REG_SZ /d "@your_new_license_server" /f
endlocal
  1. Replace "your_new_license_server" with the hostname or IP address of your new license server.
  2. Save this file with a .bat extension. For example, you could name it "UpdateLicenseServer.bat".
  3. Run the batch file as an administrator.
Article ID: 000031618
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
