Summary
Steps to develop VBA code to update Table Of Contents (TOC) symbology headings from an INFO table prior to inserting a legend in a map document.
Procedure
- Get a reference to the map document whose headings are to be changed.
Dim pMxDocument As IMxDocument
Set pMxDocument = ThisDocument
Dim pMap As IMap
Set pMap = pMxDocument.FocusMap
- Get a list of all feature layers in the TOC.
Dim pLayers As IEnumLayer
Set pLayers = pMap.Layers
Dim pFeatureLayer As IFeatureLayer
Set pFeatureLayer = pLayers.Next
- Create a pointer to an INFO file workspace.
'++ Create a pointer to the data's workspace:
Dim pWorkspaceFact As IWorkspaceFactory
Set pWorkspaceFact = New ArcInfoWorkspaceFactory
Dim pWorkspace As IWorkspace
Set pWorkspace = pWorkspaceFact.OpenFromFile("c:\geodata\covers", 0)
Dim pFeatureWorkspace As IFeatureWorkspace
Set pFeatureWorkspace = pWorkspace
- Use IFeatureWorkspace:OpenTable to open the INFO file as an ITable object; then, select all table rows using a Query Filter.
Dim pInfoTable As ITable
Set pInfoTable = pFeatureWorkspace.OpenTable("headings.lut")
Dim pQueryFilter As IQueryFilter
Set pQueryFilter = New QueryFilter
pQueryFilter.WhereClause = "FIELD_OF_HEADING_NAMES <> ''"
Dim pCursor As ICursor
Set pCursor = pInfoTable.Search(pQueryFilter, False)
Dim fieldindex As Long
fieldindex = pCursor.FindField("field_of_heading_names")
Dim pRow As IRow
Set pRow = pCursor.NextRow
- Loop through the TOC layers. You must loop through each layer because each layer can have multiple subheadings. Change each heading to the value from the heading field in the INFO table. Advance the cursor to the next table row and advance the loop to the next TOC heading.
Code:
Dim i As Integer
Dim j As Integer
Dim pLegendInfo As ILegendInfo
Dim pLegendGroup As ILegendGroup
Dim strMyHeading As String
For i = 0 To pMap.LayerCount - 1
Set pLegendInfo = pFeatureLayer
For j = 0 To pLegendInfo.LegendGroupCount - 1
Set pLegendGroup = pLegendInfo.LegendGroup(j)
strMyHeading = pRow.Value(fieldindex)
pLegendGroup.Heading = strMyHeading
Next j
Next i
pMxDocument.UpdateContents
Warning:
Run this code before you insert a legend from the Insert menu. Since this code does not capture legend properties, running it after inserting the legend would not update the legend graphic and you'd have to be rebuild from scratch.
This is not ESRI supported code. Use it at your own risk. Make a backup of your data before running this code and carefully check the output. This is just example code with no real error checking. It is meant to be a guide to develop code specific to your data inputs and desired outputs.
