HOW TO
Uninstall or overwrite a StreetMap Premium license file for ArcGIS Server (Windows)
Summary
The same DataLicInstall utility in the command prompt can be used to install, overwrite, or uninstall StreetMap Premium license files (*.sdlic) on ArcGIS Server machines, if ArcGIS Desktop is not installed. Run the command datalicinstall.exe -h (help) for more information about the utility.
Procedure
To uninstall an .sdlic license file:
  1. Open the command prompt (cmd).
  2. Navigate to the datalicinstall.exe path in the command prompt.
cd C:\Program Files\ArcGIS\Server\bin
  1. Run the following command:
datalicinstall.exe /u:<licenseFilePath><licenseName>.sdlic
To override an .sdlic license file with another license file:
  1. Follow the first two steps above.
  2. Run the following command instead:
datalicinstall.exe /o <licenseFilePath><licenseName>.sdlic
Article ID:000022381
Software:
  • ArcGIS Server
  • ArcGIS StreetMap Premium
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
