HOW TO
The uninstall dialog box for ArcIMS 4.0 on Windows does not offer an option to specifically uninstall the ArcMap Server component. As a result, you will need to uninstall the ArcIMS Spatial Server component to remove the ArcMap Server component. You can then reinstall the ArcIMS Spatial Server, if necessary.Please note that when installing ArcIMS 4.0 on Windows, the dialog box contains separate entries for ArcIMS Spatial Server and ArcMap Server; therefore, you can choose not to install ArcMap Server.
For more information on installation of ArcIMS components, see "ArcIMS Installation Guide".
Article ID:000005310
Get help from ArcGIS experts
Download the Esri Support App
