HOW TO
Test digitizer for use with ArcView
Summary
Steps to test a digitizer for use with ArcView.
Procedure
  1. Start ArcView.
  2. Select Extensions from File pulldown menu and check the Digitizer extension.
  3. Create a new view.
  4. Select the draw point tool
    Draw point tool
    [O-Image] Draw point button
    on the toolbar.
  5. Click the View menu and select Digitizer as Puck. If Digitizer as Mouse is listed, then the digitizer is already in puck mode.
  6. Use the puck's left click button to click an inch in from each corner of the digitizer tablet. You will not see any points created on screen.
  7. Press the zoom to full extent button.
    Zoom to full extent button.
    [O-Image] Zoom to full extent button
    Four points should appear on screen.
  8. Use some of the other drawing tools to test creating lines and polygons. Lines and polygons are started with the left click button and ended with the left double-click button.
Article ID:000001995
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
