HOW TO
Suppress INFO 'No match in related datafile' message
Procedure
Summary
While processing related data files, INFO displays this message whenever a no-match condition is detected:
NO MATCH IN RELATED DATAFILE relate_# FOR RECORD rec_#
This message can be supressed as shown below.
Procedure
To suppress all no match messages type this at the INFO prompt:
ENTER COMMAND > CALC $NM = 1
The INFO system item $NM determines what, if any, messages INFO displays during related data file processing when a no-match situation occurs. You can use the INFO CALCULATE command to assign $NM one of the following values:
0 - the default, directs INFO to display the this message when a no match situation occurrs:
"NO MATCH IN RELATED DATAFILE relate_# FOR RECORD rec_#"
1 - directs INFO to suppress message display when a no-match situation occurs.
2 - directs INFO to display these messages when a no match situation occurs:
NO MATCH IN related_file_spec FOR relate_key_item=item_value
For additional information, see ArcDoc > Help Topics > Working with tables > Using INFO > Appendices > System items in INFO.
Article ID:000001389
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
