HOW TO
Summarize keywords from related fields in ArcGIS Online or the Enterprise portal using Arcade
First Published: August 11, 2025
Last Published: August 11, 2025
Summary
In real-world datasets, especially in public complaints or feedback systems, related tables often contain valuable unstructured text. Summarizing common keywords from these related records helps identify recurring issues, support decision-making, and uncover spatial patterns without manual review. This article describes the workflow to summarize keywords from related fields in Map Viewer pop-ups in ArcGIS Online or the ArcGIS Enterprise portal using Arcade.
Procedure
  1. Open the web map in Map Viewer.
  2. In the Layers pane, select the layer.
  3. On the Settings (light) toolbar, click Pop-ups. Ensure pop-ups are enabled by toggling Enable pop-ups on.
  4. In the Pop-ups pane, create an Arcade expression to display the field names in the pop-ups. Refer to ArcGIS Online: Use expressions or Portal for ArcGIS: Use expressions for instructions.
  5. In the editor window, configure the expression below:
    1. Load the related feature. Replace <nameOfRelationship> with the name of the relationship between the main feature layer and the related table. Replace <fieldName> with the desired field name to only return the selected field from each related record.
var fs = FeatureSetByRelationshipName($feature, "<nameOfRelationship>", ['<fieldName>'], false);
    1. Cache the related records into an array.
var related = [];
for (var f in fs) {
    Push(related, f);
    1. Define the keywords. In this example, the defined keywords are noise, flooding, waste, traffic, and crime.
var keywords = ['noise', 'flooding', 'waste', 'traffic', 'crime'];
    1. Initialize the output list.
var summary = ["Complaint Keyword Summary:"];
    1. Iterate over each keyword, compute the number of related comments that contain it, and append the count to a summary list for output.
for (var i in keywords) {
    var key = keywords[i];
    var count = 0;
    for (var j in related) {
        var comment = related[j].Comments;
        if (!IsEmpty(comment)) {
            var txt = Lower(comment);
            if (Find(key, txt) >= 0) {
                count += 1;
    Push(summary, "- " + Proper(key) + ": " + count);
    1. Combine and return the results.
return Concatenate(summary, TextFormatting.NewLine);
The code block below shows the example of the full working script:
var fs = FeatureSetByRelationshipName($feature, "Complaints", ['Comments'], false);
var related = [];
for (var f in fs) {
    Push(related, f);
    var count = 0;
                count += 1;
  1. Click Done.
  2. In the Pop-ups pane, click Fields list and click Select fields.
  3. In the Select fields pane, under Expressions, click the expression created in Step 5 to display in the pop-up and click Done.
The Map Viewer pop-up below displays the summarized keywords from related fields.
The summarized keywords from related fields
Article ID: 000036942
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
