HOW TO
Start or stop the Oracle Listener from the command line in UNIX or Windows
Summary
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
Instructions provided describe the command line syntax for starting or stopping the Oracle Listener from the command line.
Procedure
To start the Oracle service using command line utilities, either set the Oracle home directory within the %ORACLE_HOME% environment variable or navigate to the Oracle home directory.
To start the Oracle Listener, type the following at the command line:
lsnrctl start
To stop the Oracle Listener, type the following at the command line:
lsnrctl stop
    Article ID:000009926
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
