HOW TO
Split a polyline at the vertices using ArcObjects
Summary
This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
This article contains an ArcObjects code sample that demonstrates how to split a polyline at the vertices, creating separate lines from each line segment.
Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Procedure
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl​
For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
  1. Right-click the UIButtonControl and select View Source.
  2. Copy and paste the following code into the UIButtonControl's click event.
   Dim pMxDoc As IMxDocument
   Dim pFeatureClass As IFeatureClass
   Dim pFeatureLayer As IFeatureLayer
   Dim pFeatureCursor As IFeatureCursor
   Dim pOutFeatureCursor As IFeatureCursor
   Dim pFeature As IFeature
   Dim pOutFeatureBuffer As IFeatureBuffer
   Dim pSegmentCollection As ISegmentCollection
   Dim pSegment As ISegment
   Dim pPointCollection As IPointCollection
   Dim i As Integer
   Dim index As Integer
   Dim numFeatures As Integer
   'Split lines for selected layer
   Set pMxDoc = ThisDocument
   If Not pMxDoc.SelectedLayer Is Nothing Then
     Set pFeatureLayer = pMxDoc.SelectedLayer
   Else
      MsgBox "Please select layer to split"
      Exit Sub
   End If
   Set pFeatureClass = pFeatureLayer.FeatureClass
   Set pFeatureCursor = pFeatureClass.Update(Nothing, False)
   Set pOutFeatureCursor = pFeatureClass.Insert(True)
   Set pFeature = pFeatureCursor.NextFeature
   numFeatures = pFeatureClass.FeatureCount(Nothing)
   'Loop through the features and split each feature at
   'it's vertices then copy attributes and shape to new feature
   For index = 0 To numFeatures - 1
      Set pSegmentCollection = pFeature.Shape
      For i = 0 To pSegmentCollection.SegmentCount - 1
         Set pSegment = pSegmentCollection.Segment(i)
         Set pOutFeatureBuffer = pFeatureClass.CreateFeatureBuffer
         AddFields pOutFeatureBuffer, pFeature
         Set pPointCollection = New Polyline
         pPointCollection.AddPoint pSegment.FromPoint
         pPointCollection.AddPoint pSegment.ToPoint
         Set pOutFeatureBuffer.Shape = pPointCollection
         pOutFeatureCursor.InsertFeature pOutFeatureBuffer
      Next i
      pFeatureCursor.DeleteFeature
      pOutFeatureCursor.Flush
    Next index
   pFeatureCursor.Flush
   'Refresh
   pMxDoc.ActiveView.Refresh
   MsgBox ("Completed!")
End Sub
  1. The code above calls a routine called "AddFields". To support this, copy and paste this code so it follows the "End Sub" of the Click event handler above.
   Private Sub AddFields(pFeatureBuffer As IFeatureBuffer, pFeature As IFeature)
   'Copy the attributes from the original feature to the new one
   Dim pRowBuffer As IRowBuffer
   Dim pNewFields As IFields
   Dim pNewField As IField
   Dim pFields As IFields
   Dim pField As IField
   Dim i As Integer
   Dim NewFieldIndex As Long
   Set pRowBuffer = pFeatureBuffer
   Set pNewFields = pRowBuffer.Fields
   Set pFields = pFeature.Fields
   For i = 0 To pFields.FieldCount - 1
      Set pField = pFields.Field(i)
      If Not pField.Type = esriFieldTypeGeometry And Not pField.Type = esriFieldTypeOID And pField.Editable Then
        NewFieldIndex = pNewFields.FindField(pField.Name)
        If Not NewFieldIndex = -1 Then
           pFeatureBuffer.Value(NewFieldIndex) = pFeature.Value(i)
        End If
      End If
End Sub
  1. In ArcMap, select the polyline layer whose features you want to split. Click the newly created button to split all the lines in this layer.
Article ID:000006044
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
