HOW TO
A spatially clustered table is very important for two reasons: to reduce physical and logical I/O and to improve the optimizer's calculated cost or the clustering factor for using the spatial index for Structured Query Language (SQL) statements containing spatial operators.The optimizer's clustering factor is a number representing the degree in which data is randomly distributed throughout a table in relationship with the values stored within the index.For example, when performing a spatial search at a given extent such as, a municipal boundary, if each feature is stored in an individual Oracle block, the time to fetch each feature can be substantially more than if all the features resided in the same Oracle block.Because of the distribution of data among several blocks, the time to fetch the data increases. Potentially, if the clustering factor is extremely poor, meaning very few features that are spatially clustered are physically stored in the same data blocks, the optimizer likely selects a full table scan verses using the spatial index. The reason why it becomes more efficient to perform a full table scan verses using an index is to reduce the number of I/O operations, physical or logical I/O.For example, if the spatial index was used to retrieve every row from a table, the amount of I/O would be two times or more the number of I/O operations than performing a full table scan. To use an index, Oracle must first read the index blocks, obtain the rowid for the feature to retrieve, and then read the block where the row is physically stored.Instructions provided describe how to improve performance by reducing the number of I/O operations while at the same time ensuring Oracle is able to use the spatial index efficiently by spatially clustering the table.
Code:
SELECT table_name, column_name, index_name, index_id, grid, srid
FROM sde.st_geometry_index
WHERE table_name = '<table_name>' AND owner = USER;
Code:
SELECT a.index_name, b.uniqueness, a.column_name, a.column_position
FROM user_ind_columns a, user_indexes b
WHERE a.table_name = '<table_name>' and a.index_name = b.index_name
ORDER BY a.index_name, a.column_position;
Code:
CREATE TABLE <table_name>_bk AS
SELECT b.*
FROM (SELECT s.sp_id, s.gx, s.gy,
ROW_NUMBER() OVER (PARTITION BY s.sp_id ORDER BY s.gx, s.gy) rn
FROM s<index_id>_idx$ s) sp, <table_name> b
WHERE rn = 1 AND b.rowid = sp.sp_id
ORDER BY sp.gx, sp.gy;
Code:
DROP TABLE <table_name>;
Code:
RENAME <table_name>_bk TO <table_name>;
Code:
CREATE INDEX <index_name> ON <table_name> (<column_name>) INDEXTYPE IS
sde.st_spatial_index PARAMETERS ('st_grids=<grid1,grid2,grid3> st_srid=<srid>');
Code:
EXEC dbms_stats.gather_table_stats(USER,'<table_name>');
Code:
WHERE table_name = 'PARCELS' AND owner = USER;
WHERE a.table_name = 'PARCELS' and a.index_name = b.index_name
CREATE TABLE parcels_bk AS
SELECT b.*
FROM s31_idx$ s) sp, parcels b
DROP TABLE parcels;
RENAME TABLE parcels_bk TO parcels;
CREATE INDEX a40_ix1 ON parcels (shape) INDEXTYPE IS
sde.st_spatial_index PARAMETERS ('st_grids=500,0,0 st_srid=2');
CREATE UNIQUE INDEX r132_sde_rowid_uk ON parcels (objectid);
CREATE INDEX apn_idx ON parcels (apn);
CREATE INDEX owner_idx ON parcels (owner);
Article ID:000009177
Get help from ArcGIS experts
Download the Esri Support App
