HOW TO
Sort the view's TOC alphabetically via Avenue
Summary
The sample Avenue script in this article sorts the view's Table of Contents (TOC) alphabetically by theme name.
Procedure
  1. Open a new script window.
    A. Activate the Project window.
    B. Click the Scripts icon.
    C. Click New.
  2. Copy the following code into the new window.
    Code:
    '-- Sort order of TOC by theme name
    aView = av.GetActiveDoc '-- Get the view
    theThemes = aView.GetThemes '-- Get the themes
    if (theThemes = NIL) then
    exit
    end
    theThemesName = {}
    '-- Create list of theme names as string
    for each thm in theThemes
    theThemesName.Add(thm.GetName)
    end
    '-- Sort theme name list according to user prefered order
    order = MsgBox.ChoiceAsString({"Ascending","Descending"},"Choose order for themes in TOC","TOC ORDER")
    if(order = nil) then
    exit
    else if (order = "Descending") then
    theThemesName.Sort(True)
    else
    theThemesName.Sort(False)
    end
    end
    '-- Delete sorted theme and add to top of view
    for each thm in theThemesName
    theTheme = aView.FindTheme(thm)
    aView.DeleteTheme(theTheme)
    aView.AddTheme(theTheme)
    end
    '-- Refresh TOC and view
    aView.InvalidateTOC(nil)
    aView.Invalidate
  3. Click the Compile button.
    [O-Image] Script compile button
  4. Click the Run button.
    [O-Image] Run compiled script button
Article ID:000004577
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
