HOW TO
Silently install ArcGIS Server patches
First Published: April 24, 2020
Last Published: March 29, 2022
Summary
Patches for ArcGIS Server can be installed silently in environments where a user interface is not available. Installing silently is also useful when using automated processes.
Procedure
Perform the following steps to install an ArcGIS Server patch silently.
  1. Download the necessary patch from the Esri Support Downloads page.
  2. Launch Windows Command Prompt.
  3. Enter the following command to install the patch:
msiexec.exe /quiet /passive /p <location of downloaded patch file>
The msiexec.exe command is a Windows installer, and is used to execute .msi files. The default path for this is C:\Windows\System32. Using the 'msiexec.exe -h' command in Windows Command Prompt displays the different parameters associated with msiexec.exe and their meaning.
The '/p' parameter is not displayed when using the 'msiexec.exe -h' command. This parameter indicates a patch is being applied.
Article ID: 000023214
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
