HOW TO
Sign in to ArcGIS Assistant Beta with ArcGIS Enterprise
First Published: May 29, 2025
Last Published: August 4, 2025
Summary
This article describes the steps to sign in to ArcGIS Assistant Beta with ArcGIS Enterprise.
Procedure
  • Log in to Portal for ArcGIS (Version 11.4).
  • Create a New item through the Content tab and select the Application Type as Other application.
A screenshot of a computerDescription automatically generated
  • Add Title, Select Folder, Tags and Summary.
  • Click Save.
  • An Item is created
A screenshot of a chatDescription automatically generated
  • Navigate to the Settings tab, scroll down to the Application section and enter the ArcGIS Assistant Beta URL as https://assistant.esri-ps.com
A blue line on a white backgroundDescription automatically generated
  • Change the sharing level from Owner to Everyone (public).
  • Navigate to the ArcGIS Assistant Beta page and click Sign in with ArcGIS Enterprise.
  • Enter the Portal for ArcGIS Web Adaptor URL and enter an App ID that can be found in the app created in Portal for ArcGIS.
A screenshot of a computer screenDescription automatically generated
  • Click Continue and it will open the Portal for ArcGIS login page.
  • Once logged in, the user will be able to see the content of the App ID used while logging in to ArcGIS Assistant.
Article ID: 000034445
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
