Summary
When running processes within ArcGIS Enterprise against an enterprise geodatabase, errors or performance issues may arise that require troubleshooting. Setting up the intercept logs allows for logging the communication between the client application and the enterprise geodatabase. The generated log files contain detailed information about the performed operation along with any associated errors.
After troubleshooting the issue, remember to disable the trace by removing or altering the SDETRACELOC variable, this can consume considerable disk space and significantly affect geodatabase performance.
Procedure
The instructions provided below describe how to set up and generate SDEINTERCEPT log files on a machine running ArcGIS Enterprise (Windows or Linux).
- Ensure the application is not running.
- Windows - On the machine where ArcGIS Server is installed, stop ArcGIS Server.
- Right-click the Windows button > Run > type services.msc.
- Open the Services app.
- Locate ArcGIS Server and right-click > Stop, to stop the service.
- Linux - On the machine where ArcGIS Server is installed, stop the ArcGIS Server. Execute the stopserver script on the default installation location using the following command:
${HOME}/arcgis/server/stopserver.sh
- Set up the variables for SDEINTERCEPT logging.
Note: Ensure that the target directory and folder exist with write access prior to creating the variable.
- Windows
- Open a Windows Explorer folder > right-click This PC on the left pane and click Properties.
- Scroll down and click Advanced System Settings.
- On the System Properties window, click the Advanced tab, and click Environment Variables.
- Under System variables, click New and type the following in the respective fields.
Note: The values are case-sensitive.
- For Variable Name, type SDEINTERCEPT
- For Variable Value, type crwTf
- Click OK.
- Repeat step 2d to create a new variable:
- For Variable name, type SDEINTERCEPTLOC
- For Variable value, type the desired folder location to store the log file. For example, C:\temp\intercept_log
- Click OK to close the Environment Variables window, and close the System Properties and Advanced System Settings windows.
- Linux: Set up the following environment variables using one of the these two options:
- To create temporary environment variable (automatically deleted after the machine is logged out), use the following command in the shell terminal
$ export SDEINTERCEPT=cwrTf
$ export SDEINTERCEPTLOC="<path to directory where the intercept files will be stored>"
- To create a permanent environment variable, edit the configuration Environment file in /etc folder location and add the following parameters:
SDEINTERCEPT=cwrTf
- Restart the machine.
- Launch the application:
- Windows - On the machine where ArcGIS Server is installed, start ArcGIS Server.
- Locate ArcGIS Server and right-click > Start, to start the service.
- Linux - On the machine where ArcGIS Server is installed, start the ArcGIS Server. Execute the startserver script on the default installation location using the following command:
${HOME}/arcgis/server/startserver.sh
- Run through the workflow to reproduce the issue. Navigate to the specified target directory and folder of the intercept log file to verify and review the generated log file.
- Upon completing these diagnostics, repeat Steps 1 and 2 and delete the variables created in Step 2 from the System Variable list to stop all logging processes.
- Windows
- Repeat Steps 1 through 2c.
- Delete the variables created in Step 2d from the System Variable list.
- Linux
- For the permanent environment variable, edit the configuration Environment file in /etc folder location.
- Delete the variable created from the System Variable list.
