HOW TO
Set up a CNAME in GoDaddy for a custom ArcGIS Hub domain
First Published: October 31, 2022
Last Published: July 16, 2026
Summary
The ArcGIS Hub document Use a custom domain notes that ArcGIS Hub only supports CNAME domain name service entries for custom domains and that the CNAME entry should be configured with "yourhubsite" as the "canonical name" and "hub.arcgis.com" as the "hostname".
If you haven't set up a CNAME before, this workflow can be confusing since domain name providers may use different terms for CNAME entries (For example, "value" instead of "hostname") and have preconfigured CNAME entries on newly purchased domains that don't follow the format required by ArcGIS Hub.
Procedure
In GoDaddy, remove the existing CNAME entries for the newly purchased domain and add two new CNAME entries:
  • one where the "Name" is "yourhubsite" and the "Value" is "hub.arcgis.com"
  • one where the "Name" is "www" and the "Value" is "hub.arcgis.com".
"yourhubsite" is your domain name without the top-level/sub-domains (that us, no "www" or ".com").
Article ID: 000028364
Software:
  • ArcGIS Online
  • ArcGIS Hub
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
