HOW TO
Set the path for the LIBRARIES file LOCATION item
Summary
This article shows how to set the LOCATION item.
Procedure
  1. Open a command prompt window and navigate to the ArcInfo workstation install directory.
    C:>cd %ARCHOME%/tables
  2. Start INFO and select the library. This example uses STATELIB for the library name.
    C:\arcgis\arcexe82: info
    ENTER USER NAME>ARC
    ENTER COMMAND >SEL LIBRARIES
    ENTER COMMAND >RESEL NAME CN 'STATELIB'
  3. Use LIST to check the current LOCATION directory.
    ENTER COMMAND >LIST
    NAME =STATELIB
    LOCATION =D:\OURLIBS\STATELIB\DATABASE
  4. Change the LOCATION to a valid directory and use LIST to check the update.
    ENTER COMMAND >UPDATE LOCATION PROMPT
    RECNO?>1
    LOCATION>D:\LIBS\STATELIB\DATABASE
    RECNO?>
    ENTER COMMAND > LIST
    NAME =STATELIB
    LOCATION =D:\LIBS\STATELIB\DATABASE
  5. Quit Arc
    ENTER COMMAND >QUIT
    ENTER COMMAND >STOP
Article ID:000005488
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
