HOW TO
Set the ArcMap Output Image Quality (OIQ) ratio using Visual Basic
Summary
The Output Image Quality (OIQ) setting is used to control the resampling of raster elements when outputting a map.
This setting can be controlled programatically, but the user must ensure that it is set for each data frame in the document.
Procedure
Use the code snippet below:
Code:
Private Sub ResetOutputQualityToBest()
On Error GoTo EH
Dim pActiveView As IActiveView
Dim pDisplayTrans As IOutputRasterSettings
Dim pMxDoc as IMxDocument
Set pMxDoc = ThisDocument
' This will change the setting in the 'File | Page Setup' dialog,
' but does not affect each map until the document is reopened...
Set pActiveView = pMxDoc.PageLayout
Set pDisplayTrans = pActiveView.ScreenDisplay.DisplayTransformation
If pDisplayTrans.ResampleRatio <> esriRasterOutputBest Then
pDisplayTrans.ResampleRatio = esriRasterOutputBest
End If
' ...so we will additionally set the output quality for each map so
' the current export works correctly.
Dim pMaps As IMaps
Set pMaps = pMxDoc.Maps
Dim lMapIndex As Long
For lMapIndex = 0 To (pMaps.Count - 1)
Set pActiveView = pMaps.Item(lMapIndex)
End If
Next lMapIndex
Exit Sub
EH:
Err.Raise Err.Number, "MapsOnDemand.ResetOutputQualityToBest", Err.Description
End Sub
The ResampleRatio can be set to any integer from 1 through 5, or to a member of the following enumeration:
Code:
tagesriResampleRatioType
1 - esriRasterOutputBest
3 - esriRasterOutputNormal
5 - esriRasterOutputDraft
Article ID:000003308
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
