Summary
Instructions provided describe how to set labels at a user-specified or field-based angle in ArcMap.
Procedure
- Right-click the layer name in the ArcMap Table of Contents and select Properties.
- Click the Labels tab.
- Click the Placement Options button from within Other Options.
- Click the Placement tab on the Placement Properties dialog box.
- Click the radio button for 'Place label at specified angles'.
1. Click the Angles button.
2. Enter a new angle value.
3. Click the Add Angle button.
4. Click OK.
Or at version 9.0 and higher, click the radio button for 'Place label at an angle specified by a field'.
1. Click the Rotation field button.
2. Click the drop-down list and select the appropriate field that contains rotation values.
3. Click either the Geographic or Arithmetic rotation styles radio buttons.
4. Click OK.
- Click OK on all open dialog boxes.
