HOW TO
Map Viewer Classic (a 3.x JS SDK app) is deprecated, and ArcGIS Enterprise 11.5 is the last version to support it. To encourage the use of Map Viewer (a 4.x JS SDK app), the option for setting Map Viewer Classic as the primary map viewer has been removed from both the organization and user settings. Users can access Map Viewer Classic from the App launcher and Item details page in ArcGIS Enterprise 11.5, but it will be removed altogether in 12.0.
Organizations that require Map Viewer Classic to support their workflows can set it as the primary map viewer through the ArcGIS Portal Directory (Sharing API).
Complete the following steps to set Map Viewer Classic as the primary map viewer:
https://webadaptorhost.domain.com/webadaptorname/sharing/rest
To verify the change was applied, complete the following steps:
Article ID: 000035482
Get help from ArcGIS experts
Start chatting now
