HOW TO
SQL developers may require the ability to provide an Oracle hint in a SQL statement to direct the optimizer to use a spatial index.Based upon the selectivity and cost of the spatial operator such as ST_EnvIntersects, ST_Overlaps, etc., Oracle's optimizer may either choose to use the spatial index or perform a full table scan. The decision on the best access path is determined by the table object's statistics.A SQL developer can use an Oracle hint when they know the name of the index to provide with the optimizer INDEX hint.
Code:
SQL> set autotrace traceonly explain
SQL> SELECT r.name, r.shape
2 FROM road r
3 WHERE st_envintersects
4 (r.shape,-119.34,27.97,-109.80,37.37) = 1;
| Id | Operation | Name | Rows | Bytes | Cost (%CPU)| Time |
| 0 | SELECT STATEMENT | | 71702 | 23M| 820 (1)| 00:00:10 |
| *1 | TABLE ACCESS FULL| ROAD | 71702 | 23M| 820 (1)| 00:00:10 |
Code:
SQL> SELECT /*+ INDEX (r a10_ix1) */
2 r.name, r.shape
3 FROM road r
4 WHERE st_envintersects
5 (r.shape,-119.34,27.97,-109.80,37.37) = 1;
| 0 | SELECT STATEMENT | | 71702 | 23M| 9614 (2)| 00:01:56 |
| 1 | TABLE ACCESS BY INDEX ROWID| ROAD | 71702 | 23M| 9614 (2)| 00:01:56 |
|* 2 | DOMAIN INDEX (Sel: 100) | A10_IX1 | | | 4834 (3)| 00:00:59 |
Article ID:000009237
Get help from ArcGIS experts
Download the Esri Support App
