HOW TO
Set a variable to the number of selected records in ArcPlot
Procedure
Question
How can a variable be used to store the current number of selected records in ArcPlot?
Answer
The following line will set a variable to the number of selected records:
&SETVAR X = [EXTRACT 1 [SHOW SELECT <COVERAGE> <COVERAGE_TYPE>]]
Example:
&SETVAR X = [EXTRACT 1 [SHOW SELECT LANDUSE POLY]]
SHOW SELECT only works on individual coverages or INFO files. It does not work on librarian layers or ArcStorm layers.
Article ID:000001351
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
