HOW TO
Set a specific symbol for the feature theme
Summary
The sample scripts in this article demonstrate how to set symbols for a theme.
Procedure
  • Simple legend for point and line themes.
    Code:
    '-- Create a new theme from a feature source:
    theView = av.GetProject.FindDoc("View1")
    '-- This line has to be changed for line themes. Use arc instead
    '-- of point for feature type. You will need to make changes
    '-- to the path where your data resides.
    theTheme = Theme.Make("c:\esri\esridata\usa\cities.shp".AsSrcName)
    theTheme.SetName("Calif Cities")
    theView.AddTheme(theTheme)
    theTheme.SetVisible(true)
    theTheme.SetActive(true)
    theLegend = theTheme.GetLegend
    NewLegend = theLegend.Clone
    '-- Refer the symbol palette for the number to be used with Get().
    '-- For line themes use #PALETTE_LIST_PEN instead of #PALETTE_LIST_MARKER.
    CurrSymbol = av.GetSymbolWin.GetPalette.GetList(#PALETTE_LIST_MARKER).Get(1)
    NewSymbol = Symbol.Make(#SYMBOL_MARKER)
    NewSymbol.Copy(CurrSymbol)
    NewSymbol.SetColor(Color.GetRed)
    NewSymbol.SetSize(6)
    NewLegend.GetSymbols.Set(0, NewSymbol)
    '-- Refresh the theme without refreshing other themes in the view.
    theTheme.SetLegend(NewLegend)
    theTheme.InvalidateLegend
    theTheme.UpdateLegend
  • Sample legend for polygon themes.
    Code:
    '-- You will need to make changes to the path where your data resides.
    theTheme = Theme.Make("c:\esri\esridata\usa\counties.shp".AsSrcName)
    theTheme.SetName("USA Counties")
    '-- Modified lines.
    '-- This returns a COLOR object, not a SYMBOL; thus, create a
    '-- new symbol and set its color using this returned object.
    NewCol = av.GetSymbolWin.GetPalette.GetList(#PALETTE_LIST_COLOR).Get(9)
    NewSymbol = Symbol.Make(#SYMBOL_FILL)
    NewSymbol.SetColor(NewCol)
    NewLegend = theLegend.GetSymbols.Set(0, NewSymbol)
  • Graduated legend classification.
    Code:
    '-- Sample script to manipulate the Legend of a theme
    '-- and its classifications (Values and Labels)
    '-- The example uses a legend with three classifications.
    '-- Gets the view
    '-- Get the theme. Use sample data in AVDATA. If other themes are
    '-- used, the values for classification should be changed.
    theTheme = theView.FindTheme("States")
    '-- Get legend and corresponding classifications.
    theClasses = theLegend.GetClassifications
    '-- Define the shade symbol for all the unselected countries.
    b = Symbol.Make(#SYMBOL_FILL)
    b.SetColor(Color.GetRed)
    b.SetOlColor(Color.GetBlack)
    '-- Update the legend with this symbol. This symbol is added as
    '-- the first element in the legend's symbol list.
    theLegend.GetSymbols.Set(0,b)
    '-- Define the shade symbol for the selected country.
    c = Symbol.Make(#SYMBOL_FILL)
    c.SetColor(Color.GetGreen)
    c.SetOlColor(Color.GetBlack)
    '-- as the second element in the legend's symbol list.
    '-- Symbol b is again added to the symbol list as the third element.
    theLegend.GetSymbols.Set(1,c)
    theLegend.GetSymbols.Set(2,b)
    '-- Manipulate the classification values and labels
    i = theClasses.Get(0)
    i.SetMinimum(1)
    i.SetMaximum(39)
    i.SetLabel("1 - 39")
    i = theClasses.Get(1)
    i.setMinimum(40)
    i.SetMaximum(40)
    i.SetLabel("40")
    i = theClasses.Get(2)
    i.SetMinimum(41)
    i.SetMaximum(51)
    i.SetLabel("41-51")
    '-- Update the theme with the new shades.
    theview.invalidate
  • To use these scripts:
    1. Open a new script window.
    A. Activate the Project window.
    B. Click the Scripts icon.
    C. Click New.
    2. Copy a script into the new window.
    3. Change the paths in the script to match the data on your machine.
    4. Click the Compile button.
    [O-Image] Script compile button
    5. Click the Run button.
    [O-Image] Run compiled script button
    Repeat these steps for the other scripts.
Article ID:000003933
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
