HOW TO
Set a map frame at the center of a layout in ArcGIS Pro
Last Published: December 2, 2022
Summary
Creating a layout in a project enables map elements such as map frames and legends to be strategically added and adjusted on a page designed for map printing. In certain circumstances, it is necessary to place a map frame at the center of the layout. In this example, the map frame is not set at the center of the layout.
The map frame is not placed at the center of the layout example
This article describes two workarounds to set the map frame at the center of the layout in ArcGIS Pro by using guides and adjusting the alignment of the map frame.
Procedure
Set guides at specified increments on the layout
Adding guides to the layout provides a visual reference in positioning and adjusting the size of the map according to preference. Follow the steps below to set the map frame at the center of the layout by adding guides to the layout.
  1. Open the project in ArcGIS Pro.
  2. Add a layout to the project. Refer to ArcGIS Pro: Add a layout to your project for more information. In this example, the ANSI - Landscape Letter 8.5" x 11" layout is selected.
  1. Add a map frame to the layout. Refer to ArcGIS Pro: Insert a map frame for more information.
  2. Click the Layout tab and check Rulers and Guides in the Show group.
Rulers and Guides check boxes in the Show group
  1. Right-click the ruler and click Add Guides....
The Add Guide and Add Guides options after right-clicking the ruler
  1. In the Add Guides window, under Orientation, click Both.
  2. Under Placement, click the drop-down menu and select Offset from edge.
  3. Under Margin, specify the size of the edge offset. In this example, the size is specified as '1 inch'.
  4. Click OK.
The Orientation, Placement, and Margin options, as well as OK and Cancel buttons in the Add Guides window
  1. On the layout, click the map frame and resize it according to the guides added to the layout.
The vertex of the map to resize the map frame
  1. Click Save to save the changes made to the layout.
Set the alignment of the map frame on the layout
  2. Right-click the map frame, select Align and Align to Page.
The Align and Align to Page buttons
  1. Right-click the map frame, select Align and click Align Center.
  2. Right-click the map frame, select Align and click Align Middle.
The Align Center and Align Middle buttons
The image below shows the map frame is set at the center of the layout in ArcGIS Pro.
The map frame at the center of the layout
Article ID: 000017681
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
