HOW TO
Set a graduated colors renderer with manual intervals in ArcGIS Pro using Python
Summary
Graduated colors symbology is used to show a quantitative difference between mapped features by varying the color of symbols. Data is classified into ranges that are each assigned a different color from a color scheme to represent the range. Refer to ArcGIS Pro: Graduated colors for more information.
It is possible to set a graduated colors renderer using the ArcPy module through the GraduatedColorsRenderer class.
Procedure
The following steps describe how to set a graduated colors renderer using the ArcPy module:
  1. Import the necessary modules.
import arcpy
  1. Create the parameter to specify the current project and maps.
p = arcpy.mp.ArcGISProject("CURRENT")
m = p.listMaps("Map")[0]
lyr = m.listLayers()[0]
sym = lyr.symbology
  1. Run the function to use the GraduatedColorsRenderer class and the color specification.
sym.updateRenderer("GraduatedColorsRenderer")
sym.renderer.colorRamp=p.listColorRamps("Cyan to Purple")[0]
  1. Create the parameters to set the value intervals.
classBreakValues = [25000,150000,1000000,3000000,10000000]
classBreakLabels = ["div 1", "div 2", "div 3", "div 4", "div 5"]
  1. Run the renderer.breakCount function to use the classBreakValues array parameters as the values, and create a counter.
sym.renderer.breakCount = len(classBreakValues)
count = 0
  1. Create a loop to set the renderer.
for brk in sym.renderer.classBreaks:
    brk.upperBound = classBreakValues[count]
    brk.label = classBreakLabels[count]
    count += 1
lyr.symbology = sym
The following shows the full script:
import arcpy
sym = lyr.symbology
count = 0
    count += 1
lyr.symbology = sym
Article ID: 000020468
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
