HOW TO
Select date attributes within 'days from today' in ArcGIS Pro using Select by attributes with SQL
Last Published: April 28, 2022
Summary
The steps provided describe how to select date attributes within a certain number of days from the present in ArcGIS Pro using Select by Attributes with an SQL expression.
Procedure
For example, to select records within 90 days from today:
  1. In ArcGIS Pro, go to the attribute table containing the records to filter, and click Select by Attributes.
  2. Toggle the SQL button on, as shown in the next image.
toggling the SQL option in Select by Attributes
  1. In the SQL expression box, type the following expression:
    • Where date is the date field name, and 90 is the number of the days of the period in question.
date >= CURRENT_DATE()
AND
date - 90 <= CURRENT_DATE()
  1. Run the tool.
In the image below, the date field has been selected for the Input Rows, and rows are now selected that meet the desired time constraints.
Article ID: 000026520
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
