HOW TO
The Select by Attributes tool can be used to identify or work with a subset of features on the map when querying, exploring, analyzing, or editing data. Applying a selection specifies the features to calculate statistics, view attributes, or edit the set of features that comprise a map layer.
This article demonstrates the use of the Select By Attributes tool in ArcMap to identify a specific range of attribute fields for further analysis. The LEVEL_NO field in the Schools_all feature class is used to identify the attribute fields for levels 2 to 4.
to open the Select by Attributes dialog box.
<field name> BETWEEN <field value> AND <field value>
Article ID: 000027042
Get help from ArcGIS experts
Start chatting now
