HOW TO
Search specific ISO metadata elements using ArcCatalog
Summary
The ArcCatalog Search dialog box lets you test the content of several predefined metadata elements. For example, you can search for resources by their content type classification; by their data format; and for resources that have specific words in their title, abstract, or purpose. However, searches using these predefined criteria will only succeed in finding objects that have FGDC-style metadata. Objects with ISO-style metadata can be found using the same criteria if you know which ISO XML element contains the appropriate information. Type the XML element's path into the Metadata element text box on the Search dialog box's Advanced tab. Only text comparisons can be performed against these XML elements, not date or numeric comparisons.
Procedure
  • TITLE: To look for metadata with specific words in the ISO Title element, copy the following path into the Metadata element text box: dataIdInfo/idCitation/resTitle
  • ABSTRACT: To look for metadata with specific words in the ISO Abstract element, copy the following path into the Metadata element text box: dataIdInfo/idAbs
  • EDITION: To look for metadata with specific words in the ISO Edition element, copy the following path into the Metadata element text box: dataIdInfo/idCitation/resEd
  • SCALE: In FGDC-style metadata the only place to record scale information is in the Source Information section. The ISO metadata standard defines a specific Scale element to record a dataset's scale. To look for metadata with a specific scale denominator value, copy the following path into the Metadata element text box: dataIdInfo/dataScale/equScale/rfDenom
    You won't be able to search for datasets that have a larger or smaller scale than the one that you specify, only datasets that have the same scale.
  • THEME KEYWORD: To look for metadata with specific ISO Theme Keywords, copy the following path into the Metadata element text box: dataIdInfo/descKeys[keyTyp/KeyTypCd/@value = '005']/keyword
  • PLACE KEYWORD: To look for metadata with specific ISO Place Keywords, copy the following path into the Metadata element text box: dataIdInfo/descKeys[keyTyp/KeyTypCd/@value = '002']/keyword
  • STRATUM KEYWORD: To look for metadata with specific ISO Stratum Keywords, copy the following path into the Metadata element text box: dataIdInfo/descKeys[keyTyp/KeyTypCd/@value = '003']/keyword
  • TEMPORAL KEYWORD: To look for metadata with specific ISO Temporal Keywords, copy the following path into the Metadata element text box: dataIdInfo/descKeys[keyTyp/KeyTypCd/@value = '004']/keyword
  • CONTENT TYPE: To look for metadata that falls into a specific content type as defined by the ArcIMS Metadata Service, copy the following path into the Metadata element text box: distInfo/distributor/distorTran/onLineSrc/orDesc[. = '001']
    Replace "001" in the path with the appropriate content type code as follows (e.g., use "009" to search for Map Files such as ArcReader documents):
    001 - Live Data and Maps
    002 - Downloadable Data
    003 - Offline Data
    004 - Static Map Images
    005 - Other Documents
    006 - Applications
    007 - Geographic Services
    008 - Clearinghouses
    009 - Map Files
    010 - Geographic Activities
  • DATA THEME or TOPIC CATEGORY: The ArcIMS Metadata Service categorizes documents according to the general subject of the resources they define; a document's subject category is referred to as its data theme. These themes are derived from the list of ISO Topic Categories.
    To look for metadata with a specific ISO Topic Category, copy the following path into the Metadata element text box: dataIdInfo/tpCat/TopicCatCd[@value = '001']
    Replace "001" in the path with the appropriate topic category code as follows (e.g., use "006" to search for elevation products such as DEMs):
    001 - Agriculture and farming
    002 - Biologic and ecologic
    003 - Administrative and political boundaries
    004 - Atmosphere, climatology, and meteorology
    005 - Business and economic
    006 - Elevation and derived products
    007 - Environment and conservation
    008 - Geological and geophysical
    009 - Human health and disease
    010 - Imagery, basemaps, and land cover
    011 - Military and intelligence
    012 - Inland water resources
    013 - Locations and geodetic networks
    014 - Oceans and estuaries
    015 - Cadastral and land planning
    016 - Cultural, society, and demographic
    017 - Facilities and structures
    018 - Transportation networks
    019 - Utility and communication networks
  • ORIGINATOR: To look for ISO metadata documents with specific words describing the originators (authors) of the data, copy the following path into the Metadata element text box: dataIdInfo/idCitation/citRespParty[role/RoleCd/@value = '006']/*
    This path will look for the words you specified in all elements contained within each Responsible Party section where the party is defined as an originator. If you want to search for the name of an individual, you would replace the asterisk (*) with "rpIndName". To search for an organization's name, you would replace the asterisk with "rpOrgName".
  • LINEAGE: To look for metadata with specific words in the ISO Lineage Statement element, copy the following path into the Metadata element text box: dqInfo/dataLineage/statement
Article ID:000005701
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
