HOW TO
Search for null values using the SearchCursor function in ArcGIS Pro
First Published: October 21, 2021
Last Published: November 1, 2023
Summary
The SearchCursor function is useful to extract values from a feature class or an attribute table including null values. By using a Python expression, this function lists all null values of a selected field.
The article describes how to search for null values in an attribute table using the SearchCursor function in ArcGIS Pro.
Attribute table containing null values
Procedure
  1. In ArcGIS Pro, open the attribute table of the desired feature class. Refer to ArcGIS Pro: Open tabular data for instructions.
  2. Open the Python window. Refer to ArcGIS Pro: Python window for more information.
  3. Run the following script:
    1. Define the SQL statement for the field name with null values.
import arcpy
sql = "<fieldName> IS NULL"
  1. Set the path of the feature class.
fc = r"<pathName>"
  1. Search the records using the SearchCursor function and get the OBJECTID.
cursor = arcpy.da.SearchCursor (fc, ["OBJECTID"], where_clause=sql )
  1. Print the results.
for row in cursor:
    print(row[0])
The code block below demonstrates an example of the full working script.
import arcpy
sql = "FacilityID IS NULL" fc = r"C:\Users\Documents\ArcGIS\Projects\MyProject22\MyProject22.gdb\Point1" cursor = arcpy.da.SearchCursor (fc, ["OBJECTID"], where_clause=sql ) for row in cursor:
    print(row[0])
The image below shows the ObjectIDs of the null values are printed in the Python window.
The ObjectIDs of the null values are printed in the Python window
Article ID: 000026670
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
