HOW TO
Note: This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
This sample code shows how to save a .lyr file as a blob in a database. Any object that supports persistence can be saved in this manner.
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Note: For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
' Get the IPersistStream for the 1st Layer from the map Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Dim pPersist As IPersistStream Set pPersist = pMxDoc.FocusMap.Layer(0) ' Now persist the layer to the memory blob stream Dim pMemoryStream As IMemoryBlobStream Set pMemoryStream = New MemoryBlobStream pPersist.Save pMemoryStream, False ' Finally save the blob into the database Dim pWorkspaceFactory As IWorkspaceFactory Set pWorkspaceFactory = New AccessWorkspaceFactory Dim pFeatureWorkspace As IFeatureWorkspace Set pFeatureWorkspace = pWorkspaceFactory.OpenFromFile("C:\Source\BLOB.mdb", 0) Dim pTable As ITable Set pTable = pFeatureWorkspace.OpenTable("Layers") Dim pRow As IRow Set pRow = pTable.CreateRow pRow.Value(pRow.Fields.FindField("Layers")) = pMemoryStream pRow.Store
' Finally save the blob into the database Dim pWorkspaceFactory As IWorkspaceFactory Set pWorkspaceFactory = New AccessWorkspaceFactory Dim pFeatureWorkspace As IFeatureWorkspace Set pFeatureWorkspace = pWorkspaceFactory.OpenFromFile("C:\Source\BLOB.mdb", 0) Dim pTable As ITable Set pTable = pFeatureWorkspace.OpenTable("Layers") Dim pCursor As ICursor Set pCursor = pTable.Search(Nothing, False) Dim pRow As IRow Set pRow = pCursor.NextRow If (pRow Is Nothing) Then Exit Sub Dim pMemoryStream As IMemoryBlobStream Set pMemoryStream = pRow.Value(pRow.Fields.FindField("Layers")) Dim pLayer As ILayer Set pLayer = New FeatureLayer Dim pPersist As IPersistStream Set pPersist = pLayer pPersist.Load pMemoryStream Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument pMxDoc.FocusMap.AddLayer pLayer
Article ID:000005714
Get help from ArcGIS experts
Download the Esri Support App
