HOW TO
Run a VBA macro using IVbaApplication::RunVBAMacro
Summary
The VBA sample in this article demonstrates how to run and pass arguments to a macro using the IVbaApplication::RunVBAMacro command. The arguments are passed using a Variant array.
Procedure
  1. Open the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  2. Create a new Code Module.
    Select Module from the Insert menu.
  3. Copy this sample code into the Code Module:
    Code:
    Sub RunMacro()
    Dim pVbaApp As IVbaApplication
    Set pVbaApp = Application
    Dim myArray As Variant
    'enter name and age
    myArray = Array("Jane Doe", 34)
    pVbaApp.RunVBAMacro "Project", "Module1", "MyMacro", myArray
    End Sub
    Sub MyMacro(Name As String, Age As Integer)
    MsgBox "Your name is " & Name & " and you are " & Age & " years old."
    End Sub
  4. Run the Sub procedure.
    Select Run Sub/UserForm from the Run menu.
Article ID:000003560
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
