HOW TO
RouteMAP IMS 3.0/Microsoft .NET Framework 2.0
Summary
Although RouteMAP IMS 3.0 was released prior to the release of Microsoft .NET Framework 2.0, the .NET Framework redistributables can be installed either before or after RouteMAP IMS is installed. If .NET Framework 2.0 and Visual J# are already installed, there is no need to remove them before installing RouteMAP IMS 3.0.
Verify that the .NET Framework 2.0 packages are installed by selecting the 'Add/Remove Programs' icon from the Windows Control Panel. The following items in the programs list indicate that these packages are installed:
· Microsoft .NET Framework 2.0
· Microsoft Visual J# 2.0 .NET Redistributable Package 2.0If the packages are not installed, the .NET framework can be obtained by way of the Related Information section below.
Procedure
Follow these steps to install RouteMAP IMS with the .NET updates:
  1. Verify that the .NET Framework 1.1 is installed on the server.
  2. Install RouteMAP IMS 3.0 by following steps described in the Installation Guide.
  3. If the Microsoft .NET Framework 2.0 or Visual J# 2.0 are not installed, obtain and install them by way of the Related Information section below.
  4. Reboot the server.
  5. Remove the older .NET Framework 1.1 and Visual J# packages.
Article ID:000008270
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
