HOW TO
You can rotate the text for any dimension feature whose style does not maintain the text parallel with the dimension line.
To change the style of a selected dimension feature, click the Dimension Style dropdown list and click the new style.
You can also use the standard Attributes dialog box to modify the properties of a dimension feature, or to modify the values of fields that you have added to your dimension feature class.
To rotate a dimension feature's text, type in the angle for the text. The dimension feature must reference a style that doesn't have the text set to be parallel with the dimension line.
Article ID:000003071
Get help from ArcGIS experts
Download the Esri Support App
