HOW TO
Retrieve the REST URL of ArcGIS Online hosted feature layers using ArcGIS API for Python
First Published: December 21, 2022
Last Published: December 21, 2022
Summary
The REST endpoint of an ArcGIS Online item contains useful information. However, manually obtaining the REST URL can be time-consuming if there are many items. Using ArcGIS API for Python, information such as the REST URL for each item can be generated in an Excel file. This article provides the workflow to retrieve the REST URL and other details of the ArcGIS Online items using ArcGIS API for Python.
Procedure
  1. Import the necessary modules.
from arcgis.gis import GIS
import datetime
import os, re, csv
import pandas as pd
  1. Specify the ArcGIS Online credentials to use.
gis = GIS('https://www.arcgis.com', 'USERNAME', 'PASSWORD')
  1. Search for the relevant items.
search_result = gis.content.search(query = 'owner:OWNER_NAME', item_type="Feature Service", max_items=NUMBER OF ITEMS)
#(search_result)
# list to record items
  1. Create a list parameter.
list_of_items = list()
list_of_items.append(['title', 'id', 'views', 'created', 'owner', 'size', 'access', 'url'])
  1. Store the searched items information in the created list.
for i in search_result:
  try:
      if hasattr(i, 'url'):
        #source = i.sourceUrl
        unix_date =i.created # unix ms second date/time
        normal_date = datetime.datetime.fromtimestamp(unix_date / 1e3)
        list_of_items.append([i.title, i.itemid, i.numViews, normal_date, i.owner, i.size, i.access, i.url])
  except:
   continue
  1. Convert the list parameter to a Pandas DataFrame and save the DataFrame as an Excel file in a specified folder location.
df = pd.DataFrame(list_of_items)
df.to_excel(r'<FOLDER LOCATION>\<FILE NAME>.xlsx')
print('Item details are saved in the excel file.')
The code block below shows the full script for the 20 searched hosted features owned by TestUser.
import datetime
import os, re, csv
import pandas as pd
gis = GIS('https://www.arcgis.com', 'USERNAME123', 'PASSWORD123')
search_result = gis.content.search(query = 'owner:TestUser', item_type='Feature Service', max_items=20)
  try:
  except:
   continue
df.to_excel(r'C:\Users\USER\Desktop\Download Folder\item details.xlsx')
Article ID: 000028940
Software:
  • ArcGIS Online
  • ArcGIS API for Python
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
