HOW TO
Use the Python scripts below to find the folder name for a given item in Portal for ArcGIS.
In the below example, the item ID is used to find the item and return its folder name:
#libraries import arcgis from arcgis.gis import GIS from arcgis.gis import User #variables portalurl = "https://hostname.domain.com/portal" username = "....." password = "....." #the id of the item that you want to know is in which folder #(you can retrieve the item in any other way you find suitable) itemid = "4f394f2cda81415294f96134220e0c7d" #login gis = GIS(portalurl,username,password,verify_cert=False) #retrieve item item = gis.content.get(itemid) #specify user user = User(gis,username) #retrieve the folder of the item by searching for the item id for f in user.folders: list = user.items(folder=f) for i in list: search_id = list[list.index(i)].id if item.id == search_id: print(f['title'])
Item IDs are unique to the organization, so the script in the example above only prints one folder name. In the below example, the item title is used to find the item. Unlike the item ID, there can be more than one item with the same title in the organization, and the below script returns all the items with that title and their folder names:
#libraries import arcgis from arcgis.gis import GIS from arcgis.gis import User #variables portalurl = "https://hostname.domain.com/portal" username = "........" password = "........" #the title of the item that you want to know is in which folder #(you can retrieve the item in any other way you find suitable) itemtitle= "..........." #login gis = GIS(portalurl,username,password,verify_cert=False) #retrieve item itemsearch = gis.content.search(query=f"title:{itemtitle}") #specify user user = User(gis,username) #retrieve the folder of the item by searching for the item title for f in user.folders: list = user.items(folder=f) for i in list: if i.title == itemtitle: print(f"{i} is in folder {f['title']}")
Article ID:000028966
Get help from ArcGIS experts
Download the Esri Support App
