HOW TO
Retrieve a geodatabase license file from an ArcGIS Enterprise on Kubernetes deployment for use with creating/enabling an enterprise geodatabase
Last Published: March 16, 2022
Summary
This workflow requires namespace admin privileges on a machine that can connect to the Kubernetes cluster using the kubectl client.
The resulting file should be transferred to a network share accessible to the machine running ArcGIS Pro, or the machine itself, for use as an input to the geoprocessing tools: Enable Enterprise Geodatabase or Create Enterprise Geodatabase.
Procedure
Run the following command in a bash prompt (the location can be updated to any writable path):
kubectl get secret arcgis-server-license -o jsonpath="{.data.*}" -n <namespace> | base64 --decode | grep sde > ~/geodatabase.ecp
This is applicable to ArcGIS Enterprise 10.9 and 10.9.1.
Article ID: 000027372
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
